Syph007 · 6035 · 1299118
ca Offline Syph007
  • SAK Surgeon
Reply #2790 on: June 03, 2015, 10:57:12 PM
I havent built a 58 in awhile, but here is a minichamp in blue anodized Ti, with tweezers and awl added from a 91.
Modding thread : Here
Website : WWW.SAKModder.com
Facebook : SAKModder
Instagram : robertjlessard
es Offline borjor
Reply #2791 on: June 04, 2015, 09:25:55 AM
I have another question regarding the pen: if you cut a longer slot, will it fit instead of the toothpic? P.s.: I'm trying to contact you through pm and email for a mod.
ca Offline Syph007
  • SAK Surgeon
Reply #2792 on: June 10, 2015, 12:03:00 AM
Im working on a copper accented Ti mod next.  It was actually easier to fill with copper as it flowed easier I could be less exact with the hand cutting of the + shape and it squished itself in there nicely.
au Offline tomcat
Reply #2793 on: June 11, 2015, 09:06:42 AM
Gorgeous!
ca Offline Syph007
  • SAK Surgeon
Reply #2794 on: June 11, 2015, 11:54:06 PM
I had a very old mod of mine come back for a change and it was so nice to see something come in that had been used.
This was number 83 ( Im currently working on 425 ) so this was quite an older one.
Here is what it looked like as delivered.  This was a bladeless mod.
And here is what it looks like today.  The owner decided a small blade to be of more use than can opener, and also wanted the keyring removed.
It was nice to see some worn alox, I dont get to see it often.  :D  Ive had some cerakote mods come back but they dont hold up near as well as anodize so I'll probably not bother with cerakote again.
 :salute:
ca Offline Syph007
  • SAK Surgeon
Reply #2795 on: June 12, 2015, 12:26:01 AM
And project Ti with copper is done now too.
I didn't have copper rod the right size to rivet the tweezer head together.. then after some digging in the garage I found some household wire.  Turns out the diameter of the ground wire is 1/16th inch, the exact rivet size I use and it's pure copper.  Worked great.  :D
This is a none backscale cutout build so it has the awl on back for blade layer.
us Offline sawman
  • You're amongst friends.
Reply #2796 on: June 12, 2015, 01:04:00 AM
I think that's my favorite thing you've made yet syph :tu:
SAW
Reply #2797 on: June 12, 2015, 01:08:06 AM
That's bloody stunning mate :)
Sent from my K013 using Tapatalk
us Offline Monrogue
  • Wooooo!
Reply #2798 on: June 12, 2015, 01:38:58 AM
Yup, the more of these I see, the more I want my Rogueneer to get the Ti upgrade :)
K-Tibbs
us Offline neillcurrie
  • Wanted: SpydeWrench
Reply #2799 on: June 12, 2015, 03:12:14 AM
That's superb!
Aren't you worried about a galvanitic reaction between all the dissimilar metals seizing it all together though  ;) ;)
us Offline mrynnr
  • SAK Addict
Reply #2800 on: June 12, 2015, 03:39:04 AM
Be A U ti FUL! :tu:
ca Offline Syph007
  • SAK Surgeon
Reply #2801 on: June 12, 2015, 04:01:39 AM
That's superb!
If the Al and Cu were touching yes, but since the Al is anodized its non conductive.  The Ti is pretty well inert so maybe the copper would oxidize faster?  Not sure really but we'll see what happens. :D
00 Offline kosmo
  • "All I need now i'th a can opener!"
Reply #2802 on: June 12, 2015, 09:42:01 AM
Do you have a hidden 4th pin for holding the back springs that have back side tools?  I would like to try putting a multitool hook in an 84mm alox.
WTT Book: Victorinox - A Knife and Its History, see link:
http://forum.multitool.org/index.php/topic,57788.0.html
Will trade items for new/used Cadet Alox knives for mod projects.
Updated list: https://freeshell.de/~kosmo/sak/
:B: www.radiotell.ch
ca Offline Syph007
  • SAK Surgeon
Reply #2803 on: June 12, 2015, 05:08:00 PM
Yes I drill into the scale of each side about 2 mm with carbide PCB circuit board drill bit of 2.2mm and that works perfect.
84 alox scales are too thin to sink a hole that far but you might be able to get it deep enough to work if you use a 2.2mm endmill after first spotting the hole with a standard pointed drill bit.
Reply #2804 on: June 12, 2015, 06:41:30 PM
Now for the next step: embedding a 1 carat diamond into the Tweezer copper end
 :rofl: :rofl:
ca Offline Syph007
  • SAK Surgeon
Reply #2805 on: June 12, 2015, 07:42:37 PM
 :rofl: :rofl:
Good guess! But not diamond...  :whistle:  I'm practicing my gem setting first though.
us Offline twiliter
Reply #2806 on: June 16, 2015, 02:35:47 PM
A couple of questions for you Syph, and maybe this was covered elsewhere, but what is required to put a small blade in a 93mm in place of the awl, is there a factory spacer that works?
And, is the file from a 91mm a direct drop in on a 93mm saw spring?
Thanks in advance, I'm trying to figure out what to send you for a custom, if you're willing and still taking 93mm requests.
ca Offline Syph007
  • SAK Surgeon
Reply #2807 on: June 16, 2015, 03:57:16 PM
A small blade is a wee bit thinner than the awl, so I make little washers to fill out the remainer of the space, but other than that they fit no problem.
91mm file works on the 93mm saw spring with no changes needed (other than making the pivot hole bigger).
us Offline twiliter
Reply #2808 on: June 16, 2015, 05:52:04 PM
i
Thanks, will continue on PM...  :cheers:
ca Offline Syph007
  • SAK Surgeon
Reply #2809 on: June 18, 2015, 08:38:28 PM
I still have a decent stash of BO'd 93mm parts but they dont get asked for too often.  Here is one I put together today on request.  A good combination of tools in 3 layers.  :D
us Offline sf_duke
Reply #2810 on: June 19, 2015, 02:08:36 AM
Beautiful BO double blade Syph...even better on the 93mm frame so they can be on opposite pivots.  Nice work.
us Offline captain spaulding
Reply #2811 on: June 19, 2015, 02:32:44 AM
Excellent work.  :drool:
You had to go and ruin it with the combo tool though.  :P
I'm the milk man!
ca Offline Syph007
  • SAK Surgeon
Reply #2812 on: June 19, 2015, 11:29:28 PM
I got some more 91mm alox in.  I machined a tweezer slot in a few this time.  :D
I love this 4 layer setup.  Lots of tools and still reasonable on thickness.  Every layer has a backtool and no hook on scissors layer for the hook haters either... :D
CNC machined 6061 Al scales
Black hard anodized
Brass liners
Brass Nub on tweezers
1.  combo tool / main blade / phillips
2.  metal file / chisel
3.  wood saw / fine driver
4.  scissors / awl
ca Offline Syph007
  • SAK Surgeon
Reply #2813 on: June 21, 2015, 12:42:33 AM
I forgot the customer wanted the wire cutter mod to the scissors so I added that.  Id never tried it before but wow it does actually cut wire pretty darn good.   :tu:
us Offline MachoGrande
Reply #2814 on: June 21, 2015, 05:04:14 AM
Just made it through this entire thread. Amazing work, Syph. I'm inspired. Seeing as how you don't work on 84mm, I may take a stab at modding my Cadet. If I may ask, can the saw from a 84mm Lumberjack replace the blade in a Cadet. Usually the saw in an 84mm pivots on the "fat" end. Will it work on the skinny the end in place of the blade?
ca Offline Syph007
  • SAK Surgeon
Reply #2815 on: June 23, 2015, 03:59:46 PM
Wow you need a prize for reading the whole thread! :D  The saw only works on the saw backspring as far as I know.  Its not a tapered tools like a blade and its the same thickness the whole way, so its not a good tool to share with another tool in the same layer.
ca Offline Syph007
  • SAK Surgeon
Reply #2816 on: June 23, 2015, 04:00:00 PM
I promoted 3 stock alox saks to Electrician + scissors config.  :D
us Offline twiliter
Reply #2817 on: June 23, 2015, 04:35:43 PM
Love the OC's, thinking about round 2 even before 425 arrives... :facepalm:
Nice work Syph!  :cheers:
Reply #2818 on: June 23, 2015, 11:06:47 PM
Thanks! I'll let you know where to send my free custom sak! :D
Thanks for the info regarding the saw. That makes a lot of sense as to why I never see a 93mm saw sharing a layer with something like an awl.
So if I was looking for a slim, bladeless 93mm sak that featured a saw, a cap lifter, an inline phillps and an awl, could the awl sit opposite the inline phillips next to the cap lifter?
us Offline detron
  • Tool Carrying Linux User
Reply #2819 on: June 24, 2015, 02:51:48 AM
any guidance on the scissor mod for wire cutters?  it looks straight forward,  but, looks can be deceiving
If I can help, let me know
