Leatherman Wingman Half handle mod
00 Offline Sam Lim
on: November 30, 2020, 05:37:11 PM
Inspired by one of the mod I have seen recently.. This time round, I had a Wingman frame and blade, other parts I took apart a Rev.. RIP...
The micarta scale was originally 6mm thick and I was quite hesitant to thin it down, I couldn't get other stocks around here.. Its was relatively easily to sand down but dust where everywhere....... :facepalm:
There are quite a few half tools mods around so I tried to work on thing a little differently.. I find the Wingman/sidekick's half handle are easier to deploy than a half wave. And, the pocket clip are already on the correct handle.
My take on a half Wingman.
Micarta scale with a steel liner beneath. Courtesy of Rev.
It wouldn't be me if I have left the blade alone. Shortened as usual... Most likely to be replace with the Rev blade once the partial SE blade irritate me enough..
"Outside" tools. I manage to squeeze in a smaller screwdriver that doesn't come stock, slip joint. House in the same tool bay as the knife layer.
What it's packing.
Getting them to point in the correct direction...
Everyone's favourite scissor.  :cheers:
Again, tool load may change as I think I can squeeze in one more tool on the "plier's" pivot.  :multi:
Re: Leatherman Wingman Half handle mod
Reply #1 on: November 30, 2020, 05:46:52 PM
This is so well put together! And that micarta scale! :drool:
Another excellent mod. :hatsoff:
Reply #2 on: November 30, 2020, 06:15:47 PM
 :iagree: :o :drool: :drool: :drool:
Love the Micarta handles :dd: I agree that the Wave is a bit to thin and that is why I went with the Charge handle for mine :salute: I may end up with an extra handle after breaking apart a Wingman and a Sidekick later on :think: I would love to have something that turned out looking like that :drool:
Love the old school scissors as well :dd: Sweet modding as always, Sam :tu: :like:
Reply #3 on: November 30, 2020, 06:17:50 PM
Did you put micarta on the side with the clip or just the one side :think: either way it sure has a nice look to it :drool:
EDIT Nevermind, I see now that it is just the clip :tu:
Reply #4 on: November 30, 2020, 06:28:47 PM
Cool mod !    :like:
00 Offline Sam Lim
Reply #5 on: November 30, 2020, 06:47:00 PM
 :hatsoff: First time working with scales!
Only on the knife side. Originally wanted to just use it without the liner but realised the knife edge will be exposed. Thats where the Rev frame came into play. I used one part of the frame that have a spring tab and not  the outer layer so I can sneak in the small screw driver. Alot more work to fit but I think its worth it. The clip side wasn't planned for.. It looks clean so I decided to leave it as is. It would make it alot thicker too..
Cool mod !    :like:
   :D :cheers: :cheers:
00 Offline Sam Lim
Reply #6 on: December 01, 2020, 03:06:04 AM
Actually i might want to do that at some point of time. That will help to iron out some things. I think I may be addicted to scales now. Just did an order again for the 6mm micarta...... And I still have balance..
00 Offline Sam Lim
Reply #7 on: December 05, 2020, 04:09:59 PM
So I put in scales on both side  :D .Absolutely love it. Handles easier too. Replaced the pocket clip for the dangler. I still prefer deep carries. Changed out the partial serrations. Looks cool but getting on my nerves and too short to be useful.  :cheers:
Also doing some minor change to tool load. Not completed yet thats why there are 2 philips in there. So I manage to squeeze in on more on the "pliers" side.
Reply #8 on: December 05, 2020, 05:29:49 PM
ca Offline AndyS
Reply #9 on: December 06, 2020, 04:44:53 AM
Wow that’s an amazing mod - great work  :woohoo: :woohoo: :ahhh :ahhh
00 Offline Sam Lim
Reply #10 on: December 06, 2020, 07:43:12 AM
00 Offline Sam Lim
Reply #11 on: December 06, 2020, 07:52:02 AM
This should be the final! Reprofiled the blade slightly, changed some tools.
Tools are pretty nicely stacked I think.
Fitted 3 tools on the " pliers" end.  :D Thinned down the edge of the large flathead as it does not fit anything that I have and tool thick to work for prying...
Fashioned a marline spike from a damaged philips.
This should complete this mod.  :cheers: :cheers:
Reply #12 on: December 06, 2020, 08:45:42 AM
It keeps getting better and better! :like:
More! More! :cheers: :pok:
Reply #13 on: December 06, 2020, 01:48:33 PM
 :iagree: :tu:
Reply #14 on: December 06, 2020, 04:39:16 PM
So... would now be the best time to send you my address :whistle:
Awesome work, Sam :dd: I can never seem to say that enough  :salute: :like:
wales Offline GearedForwards
Reply #15 on: December 09, 2020, 03:24:36 AM
Oh my what a mod! Finally a good use for the Rev, makes me look sideways at mine and the Dremel  :facepalm:
Reply #16 on: December 09, 2020, 03:54:02 AM
Yeah, if they're gonna sell single handle tools, this is the way. :cheers:
00 Offline Sam Lim
Reply #17 on: December 09, 2020, 03:21:56 PM
This is a keeper. You can send your address to Fuzzy. I am sure he have some fun pack ready to send out.  :pok: It's fun!
Yes some of the parts did come in handy. I am quite fond of Rev actually, Basic but functional. After doing something to the gorilla wide handle splay...
 :cheers: Basically, this quite similar to a T2/T4 or Sak.. I just added scales to a rather simple mod. Not sure why, I had a pretty fun time doing this as compare to my other tinkerings ...
00 Offline Sam Lim
Reply #18 on: December 09, 2020, 03:29:02 PM
Final update.... Same function, just a different implementation. This should stay........ :whistle:
In went the rebar file. I always love a good file.
Put in a longer flathead. This should be more useful than the file/flathead set up. Changed out the OG scissor to a modern one. After a few use, I got reminded I didn't like the way the OG scissor's handle have a life of its own..
 :cheers: :cheers: :cheers:
Reply #19 on: December 09, 2020, 11:10:08 PM
yay, a new model so quickly! :like:
Reply #20 on: December 10, 2020, 12:22:42 AM
I am sure it's fun but I am not sure I want to know what kind of fun :dwts: Actually he sent me a few things in a box a couple years or so ago and it was some pretty good stuff  ;) :D
I still want that mod :ahhh It's even better now than it was before :drool: :drool: :drool: :D
I too love a good file :dd: and the tool set is looking very awesome now, Sam :salute: :like: :like:
Reply #21 on: December 11, 2020, 03:25:03 PM
Not bad, but... no bottle opener?!
 :pok: :pok:
Apart from that, excellent work! Great tool set and looks great!
 :tu: :tu:
00 Offline Sam Lim
Reply #22 on: December 11, 2020, 05:17:01 PM
 :pok: :pok:
 :tu: :tu:
I am one of those very odd person that does not drink alcohol at all. Not even during celebrations. I would really love to though but I dun know why.. I just cannot enjoy the taste at all...  :facepalm:
Total Receipts: $135.65
PayPal Fees: $8.11
Net Balance: $127.54
Below Goal: $172.46
43%
