The December 2024 Utility Knife Challenge
Farmer X · 503 · 24696
Re: The December 2024 Utility Knife Challenge
Reply #330 on: December 20, 2024, 05:33:21 AM
Day 19
Pulled the  utility knife from the tool bag.
us Offline JonesE
Reply #331 on: December 20, 2024, 05:38:47 AM
Day 19
Had the Surge and my first Fastbank with me today. Used the fastback to open a package of Pentel P205 mechanical pencils.
JonesE
Offline kaevin
Reply #332 on: December 20, 2024, 06:30:47 AM
Day 19
JonesE
Nice duo, I like P205 as well, I have the P209.
Reply #333 on: December 20, 2024, 06:36:56 AM
This one is interesting, what is the model? Is there a photo showing the blade as well? Olfa is really a "no BS brand".
Olfa CTN-1
Offline kaevin
Reply #335 on: December 20, 2024, 11:19:59 AM
Olfa CTN-1
Nice! And the blade has 5 snap off sections!
Reply #336 on: December 20, 2024, 03:09:24 PM
Day 20
Loopcutter is right. These are great lotto scratchers.
us Offline IMR4198
Reply #337 on: December 20, 2024, 05:53:40 PM
  Is that a winning ticket?  I don't know how to read the things.  Best wishes.  G
 :popcorn:
Reply #338 on: December 20, 2024, 06:16:31 PM
Day 20
Inspected the Gerber, to determine how to exchange the blade!
The slide movement is not smooth. Sticky to deploy and nearly impossible to retract. Required pliers to coax the mechanism back.
I will not carry.
And, yes the blade slide is well lubricated.
Gerber would have been wise to line the slide with thin teflon strips or such.  The mech is a pain!
Reply #339 on: December 20, 2024, 06:17:23 PM
Day 20
 :cheers: :hatsoff:
us Offline JonesE
Reply #340 on: December 20, 2024, 08:57:47 PM
Day 20
Got the Free. P4 and fastback with me today. A little later, the fastback will assist me while I wrap some packages for Christmas.
JonesE
Reply #341 on: December 20, 2024, 10:00:39 PM
 :popcorn:
Yep, $4. Came in a card from a guy at work.
Reply #342 on: December 20, 2024, 11:06:21 PM
Day 20
I used the sliding box cutter to open a package.  I vaguely remember these came from ULINE or some other industrial supply company in a box of 50 and even though the blade is replaceable they were considered disposable because they were so cheap.  Admittedly I haven't used this one in years but I'm glad I didn't throw it away.
Reply #343 on: December 21, 2024, 01:36:09 AM
@cody6268: I enjoy Propel every now and then!
@kaevin: somehow I think I'd prefer the notch to the slider.
@AzteCypher: is that granite? If so, hope you didn't have to install them!
@ReamerPunch: I ate a lot of pizza yesterday and the day before. What was on yours?
@LoopCutter: shame the Gerber was so recalcitrant!
@JonesE: I'm still thinking a Fastback would be a nice pick-up!
@BPRoberts: $4 is better than $0!
@Alan K: I wore out a lot of those sliding jobbies. They must have been really cheap, because I was never given just a new blade.
Day 20
Why the folks at Scott ABF Exchange felt the need to zip-tie my new watch to its plastic holder is a mystery to me. But at least it gave me some challenge fodder.
The objective was simply to cut the offending object. Both blades did so without issue. The result: another tie.
Utility knife record: 15-0.
Stanley record: 3-3-2.
DeWalt record: 3-3-2.
Offline kaevin
Reply #344 on: December 21, 2024, 02:16:51 AM
Day 21
Olfa PL-1
Made in Japan goodness
The package arrived before Christmas. Here it is the L-size autoload cutter. I originally wanted to get a L-2000RP but the price is very high. And given I have not acquired as many Ofla  as NT cutters, I decided to get this one (and another Olfa) for Christmas.
Front
Back with reloading instructions
Tajima for size comparison
« Last Edit: December 21, 2024, 02:47:29 AM by kaevin »
Offline kaevin
Reply #345 on: December 21, 2024, 02:20:01 AM
Continue
Top
Bottom
The body is made from fiberglass reinforced plastic. It gives a satin and warm touch. The yellow is a more muted one instead of the usual Olfa yellow.
One feature that is commonly seen on higher grade L size cutter is this dial screw for locking the blade in front. Olfa calls it W (double) lock. It is the best place for stablizing the blade, giving less length to flex.  And it stresses near to the tip, making the stresser part being discorded rather than stressing the back.
Speaking about the tip, with its bent part, is very well made. Giving no play at all even without the lock screw.
It features the same autoload chamber mechanism with LTD-04, but an enlarged one. IMO the mechanism looks more in line with the L sized cutters and isn't enlarged due to having the extra things in the gut.
Chamber opened
To open the compartment, push the red lock from the back and slide the black end part to the end and the compartment will be pushed open by the backing spring.
From the back of the compartment, I can see the rail is being slided into the plastic handle, and fixed with a screw afterwards.
« Last Edit: December 21, 2024, 02:47:05 AM by kaevin »
Offline kaevin
Reply #346 on: December 21, 2024, 02:24:00 AM
Continue
This one seems to have been in the storehouse for a loooooong time. The blades oil between the blades is dried up and sticked together. Making it impossible to slide out the first blade and I thought it was defective. A light pry between the blades with a Tajima fixed that.
The blades a all sticked together
Blade out, the cutter is very nice to hold.
This PL-1 is a nicely made auto load L size cutter with a screw lock. It is much cheaper than the NT counterpart. I am going to put all the HFL blades inside it and throw away the extra HFL. But I am keeping one of them incase someone want to lend a cutter.
Action shot opening box for Christmas decorations
« Last Edit: December 21, 2024, 02:49:47 AM by kaevin »
Reply #347 on: December 21, 2024, 05:51:27 AM
I've helped install it before but I've never done it myself.  It's heavy and scary.  Scary in that I don't want to break it while installing it.  :dwts:  I'd rather pay someone else to do it.
Day 20
The  package says these battery blister packs are baby proof.  I think they're idiot proof because it took me longer than necessary to get the battery out.  The EAB had to come in and save me from further embarassment.   :facepalm:
Reply #348 on: December 21, 2024, 08:07:10 AM
Pepperoni, mushrooms, cheese and pizza sauce. It tasted so good!  :drool:
Offline kaevin
Reply #349 on: December 21, 2024, 09:51:42 AM
Day 20
I always feel they are extremely hard to open even with a pair of scissors. If I use cutters I am afraid of scratching the cell inside. I'm just too careful.
That's why they are selling both.  :drink:
Reply #351 on: December 21, 2024, 09:33:20 PM
Day 21
This was one part of a two pack of Milwaukee Fastbacks we bought earlier this year. We call it a "his and hers" set. This one is the "hers" and mostly sits on my wife's desk.
I used it to make an ice melt scoop out (I warmed up the cider to drink after I cleared the snow).
Reply #352 on: December 21, 2024, 11:40:08 PM
Day 21
Another month, another 40-pound box of cat litter. :facepalm:
Reply #353 on: December 22, 2024, 01:58:04 AM
Day 21
A package expected on Monday arrived today, surprise!!!
The flip side, an Amazon package expected today,  Now will not arrive until Tuesday, maybe.   Strike!
Offline kaevin
Reply #354 on: December 22, 2024, 03:01:31 AM
Day 22
PL-1 has a mission to fix my racing shoes.
The outsole is coming off and some of it has deformed. Some already lost as well in last race
Cutting away the deformed part as it cannot be stick and will just peel off the whole thing, PL-1 in the back
Fix with clamps and tape
Hope it holds for 1 marathon
« Last Edit: December 22, 2024, 05:05:03 AM by kaevin »
Offline kaevin
Reply #355 on: December 22, 2024, 03:14:02 AM
  Oops double posted
Reply #356 on: December 22, 2024, 03:31:19 AM
Day 19
No use today.  The pocket clip was not easy to bend because of the odd shape.  It is shaped like a hockey stick to accommodate the string cutting notch and this odd shape made it want to twist rather than bend under the force of the pliers.  If I had to do it again, I think it might be better to remove the pocket clip first, then use the counter force of two pliers against each other.  I could bend it however and wherever I wanted it bent, then reattach the adjusted pocket clip to the knife. :cheers:
I think I have a silver version I bought at Dollar General a few years ago. Seem to recall the same problems with the pocket clip.
Reply #357 on: December 22, 2024, 03:37:03 AM
Day 19:
Basically nothing.
Reply #358 on: December 22, 2024, 03:40:28 AM
Day 20:
For dinner tonight, I threw a Sam's Club BBQ sandwich in the microwave.
As long as you follow the directions to the tee, they're edible.
However, I prefer to add cheese, an acceptable amount of BBQ sauce, and pickles.
I had to open up new packs of each.
And remove the seal from a new gallon of milk.
Reply #359 on: December 22, 2024, 09:52:16 AM
Day 22
Knipex Cutix assisting with my cardboard curtain.
